typr r problem
Old Oct 11, 2005 | 01:10 PM
Pojazz's Avatar
Default typr r problem
i have a eg hatch with ctr swap on a cold moring it strugles to stay running for about five min it will die at least 3 times after about five min of running its fine doesnt do this when warm.
2. is it possable to have bad o2 sensor and computer not read. when its warm out i get about 200 mpt i have noticeed when its cooler i get about 250 mpt does the o2 have anything to do with this both times is using no vtech
Old Oct 11, 2005 | 11:22 PM
:Andrew's Avatar
Default Re: typr r problem (Pojazz)
i wish i knew the answer have a very similar problem
Old Oct 12, 2005 | 01:51 PM
Pojazz's Avatar
Default Re: typr r problem (gsrdx)
at the gas station today turned car off went to get it wouldnt start seems to be idiling better when cold after i changed the plug wires back to 11 mm instead of stock?
Old Oct 13, 2005 | 12:31 PM
Pojazz's Avatar
again to day at the gas station the car hesitated to start i turned the key about ten times before the ecu decided it wanted to work could this be a dirty ecu maybe when i first got it it sat on a self and didnt want to work till i got it cleaned. the coms not sitting behind carpet or anything really to protect it just mounted to the inside of firewall could this be the same problem?
n/aeghatch56
Dec 21, 2011 07:13 AM
Dodger2940
10
May 11, 2006 03:06 PM
dogbiscuit
10
Oct 17, 2005 02:38 PM
n3tfury
Feb 21, 2005 08:50 AM
Chuck Dean
Jul 4, 2004 10:55 PM
