h22 eg fuel filter problem
Old Oct 20, 2005 | 10:35 PM
LD_EGSICK's Avatar
Default h22 eg fuel filter problem
stock fuel filter set up is hitting the throttle body and tps sensor and i bent back the bracket and still won't clear the intake pipe. i did a search about people doing inline fuel filter. any body have a DIY on how to do it?
Old Oct 21, 2005 | 01:22 PM
fastwanabe's Avatar
Default Re: h22 eg fuel filter problem (LD_EGSICK)
you need to unbolt off th firewall and move it next to the battery. It will require you to bend the line a little bit.
it should looks like this
Old Oct 21, 2005 | 04:49 PM
LD_EGSICK's Avatar
Default Re: h22 eg fuel filter problem (fastwanabe)
thanks, any body using a inline fuel filter?
Old Oct 21, 2005 | 09:39 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LD_EGSICK &raquo;</TD></TR><TR><TD CLASS="quote">thanks, any body using a inline fuel filter?</TD></TR></TABLE>
nope, easiest way is just to move the stock one
Old Oct 22, 2005 | 05:22 PM
v4lu3s's Avatar
RTFM
i am using an nline, but i also have upgraded fuel lines as well.
Old Oct 22, 2005 | 08:55 PM
sheepey's Avatar
if you wanna use inline...go to autozone and get FF504 filter, they're out on the show floor. Will work perfect
Old Oct 24, 2005 | 06:38 PM
Cute EK's Avatar
Default Re: (sheepey)
Im using the stock one and I didnt have to relocate it. (Its real close to the intake though...)
Old Oct 24, 2005 | 08:09 PM
high_revs's Avatar
Default Re: (Cute EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cute EK &raquo;</TD></TR><TR><TD CLASS="quote">Im using the stock one and I didnt have to relocate it. (Its real close to the intake though...)</TD></TR></TABLE>
my rubs on my intake as well
Old Oct 24, 2005 | 08:37 PM
Cute EK's Avatar
Default Re: (SB tuning)
My only probs with the H22 swap in my EG hatch are-One of my axles keeps coming out of the seal and the speedometer isnt working.
Old Oct 24, 2005 | 08:54 PM
high_revs's Avatar
what side axel, and what axle did you use?
Old Oct 24, 2005 | 09:11 PM
Cute EK's Avatar
passenger side. i used some cheap abc driveshaft axles, it said they were meant for a h22 in a 92-95 civic! i already had to modify one of them with a 90 integra axle so it wouldnt bind as bad. it still does a little bit around corners though.
Old Nov 2, 2005 | 05:15 AM
SiRTifiedacc's Avatar
i'd recommend using the accord midshaft and 90-93 integra axles.. i did that and it went in easy with no problems
Old Nov 2, 2005 | 06:22 PM
Cute EK's Avatar
Default Re: (SiRTifiedacc)
well i got it too work better by replacing the outer half with a 90 integra axle.
Old Nov 3, 2005 | 07:55 PM
DxTrix's Avatar
Here is a pic of how my buddy did it on his eg with a stock filter and on my eg with a inline filter. I also used the inline filter on my ek but I do not have any pics of it.
Old Nov 4, 2005 | 08:55 AM
93civic_sedan's Avatar
yes unbolt it thats what mine looks like...
Old Nov 4, 2005 | 10:01 PM
AMS MIKE's Avatar
Default Re: (DxTrix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix &raquo;</TD></TR><TR><TD CLASS="quote">Here is a pic of how my buddy did it on his eg with a stock filter and on my eg with a inline filter. I also used the inline filter on my ek but I do not have any pics of it.
SEXY cars!!! i too had an inline fuel pump with all steel-braided lines.
Old Nov 8, 2005 | 10:45 PM
IOSUA's Avatar
what is the stock fuel psi on the jdm h22?
xsi-t
May 30, 2011 05:16 PM
adam00
Mar 11, 2010 09:31 AM
crazyguy
11
Aug 25, 2007 01:03 PM
WayneGro
Oct 24, 2003 04:58 AM
LoudAccord
Mar 26, 2003 01:48 PM
