H22 in Eg hatch
Old Mar 9, 2006 | 06:03 AM
2DoorBandit's Avatar
Default H22 in Eg hatch
so i purcased a 92prelude(oraginally came with an 23non vtec) but some where along the line someone swapped in an 02 h22 motor in it still keeping the H23 Ecu and tranny. i totaled it like a month after i got so im pulling the motor out in putting it in an eg hatch will it be plug and play or is tyhis going to be very difficult. i think that the 92 lude is OBD1 and so is that hatch but the mtor is OBD2
Old Mar 9, 2006 | 06:11 AM
2point2's Avatar
Default Re: H22 in Eg hatch (2DoorBandit)
it's not much harder than any other swap if you have a set of mounts (www.hasport.com) and a jumper harness..
hit the search button
Old Mar 9, 2006 | 10:00 AM
MrMike's Avatar
Default Re: H22 in Eg hatch (2point2)
https://honda-tech.com/zerothread?id=650329
read up.
Old Mar 10, 2006 | 06:42 PM
sikciv666's Avatar
Default Re: H22 in Eg hatch (MrMike)
anything is possible..
Old Mar 11, 2006 | 11:23 AM
T
Default Re: H22 in Eg hatch (sikciv666)
do it thats what I have in my hatch. Just dump the pos tranny and ecu. Youll need EG motor mounts itll require some modification to the engine bay. Get a OBD2toOBD1 jumper harness. Youll need different axles. I would also suggest getting some stiffer suspension like Omni Power.
Old Mar 12, 2006 | 06:14 AM
. o 69 o .'s Avatar
Default Re: H22 in Eg hatch (H22Hatchie)
i actually used my civic engine harness, less modification in the long run
Old Mar 12, 2006 | 07:54 AM
JDMRice's Avatar
Default Re: H22 in Eg hatch (. o 69 o .)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . o 69 o . &raquo;</TD></TR><TR><TD CLASS="quote">i actually used my civic engine harness, less modification in the long run</TD></TR></TABLE>
same here.
Old Mar 12, 2006 | 06:37 PM
v4lu3s's Avatar
RTFM
02 h22 huh? thats a rare one!
Old Mar 12, 2006 | 07:28 PM
dapaur's Avatar
Default Re: (v4lu3s)
make sure you gets mounts and axles good mounts or you will be like me paying out the *** for new axles and now i gotta get mounts built and buy my mount hcp eg-h22 mounts never used brand new in box 225
Old Mar 12, 2006 | 08:09 PM
B18eg-T's Avatar
Default Re: (dapaur)
yea just get the conversion harness from a OBD2 to a OBD1. Mounts for the EG for a H22 from like Hasport. Axles.....get ones made so they don't break on you like every couple of hundred miles lol. Driver side breaks on me a lot. Ummmm what else.....I used a PO6 converted to a P28 with it chipped with uberdata with datalogging(Runs like a champ with that ECU. Use to run the stock P13 and it ran like ****) Umm yea get some good suspension like Omni Power.
I did a JDM H22 Swap into a EG
Old Mar 13, 2006 | 01:46 PM
. o 69 o .'s Avatar
Default Re: (B18eg-T)
My swap was cleaner
Old Mar 13, 2006 | 03:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18eg-T &raquo;</TD></TR><TR><TD CLASS="quote">yea just get the conversion harness from a OBD2 to a OBD1. Mounts for the EG for a H22 from like Hasport. Axles.....get ones made so they don't break on you like every couple of hundred miles lol. Driver side breaks on me a lot. Ummmm what else.....I used a PO6 converted to a P28 with it chipped with uberdata with datalogging(Runs like a champ with that ECU. Use to run the stock P13 and it ran like ****) Umm yea get some good suspension like Omni Power.
where did you get your axles made
Old Mar 16, 2006 | 10:19 AM
Ruthless671's Avatar
Default Re: (. o 69 o .)
Mine's cleaner
[IMG][/IMG]
Old Mar 19, 2006 | 04:50 AM
. o 69 o .'s Avatar
Default Re: (Htwenty2)
nice
Old Mar 19, 2006 | 10:06 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htwenty2 &raquo;</TD></TR><TR><TD CLASS="quote">Mine's cleaner </TD></TR></TABLE>
oh yeah......
PS- An OBD1 GSR harness is the easiest harness to use, plugs right into the OBD1 H22 motor with only the typical alternator wire extensions needed
diego92vx
K Series
Aug 30, 2018 06:45 PM
Noah King
K Series
Jun 20, 2018 09:28 AM
hbr
10
Jan 28, 2008 11:00 AM
2DoorBandit
Mar 9, 2006 06:31 AM
