B18c In Civic Problems
Well I just did a compression test and it came out like this 220/230/220/215 does that seem right? The engine is a 95 jdm Gsr with around 30,000-40,000 miles on it and also when I drive and come to a complete stop it seems like it going to die but it doesn't and once in awhile it'll die. I really have no clue whats wrong maybe need a valve adjustment? Any input on this would be great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote">compression looks ok... the engine dying sounds more like an IACV has gone **** up or is disconnected...</TD></TR></TABLE>
that or check all your vacuum hoses.
test the IACV and check all vacuum lines for small leaks. use a vacuum tester tool to check your vacuum system. you can probably get it at kragen, pep boys, autozone, etc...
cornhusker
Sep 20, 2003 11:36 PM
