H22 oil leak
H22 oil leak
I noticed a dribble of oil on the pavement today. I jacked up the car and found that the oil was leaking from a bolt that was about to fall out of my engine block. I tightened it back in but I have no idea what the bolt is... It is on the DRIVER's side right above the axle.. It's a 12mm bolt with a washer. Right above the oil pan and axle...
Please let me know. Thanks
Anthony
picture available upon request i suppose
EDIT: Driver's side (sorry)
Modified by 93preludeh22 at 7:28 AM 3/4/2006
Anthony
Looking from the rear of the engine (underneath car...) If you look directly above oil pan to the left of driver's side axle support that connects to block.
Re: (93preludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 »</TD></TR><TR><TD CLASS="quote">Looking from the rear of the engine (underneath car...) If you look directly above oil pan to the left of driver's side axle support that connects to block.</TD></TR></TABLE>
Is it on or behind the timing cover?
Get a pic if you can.
Re: (poison)
It appeared that oil was coming out from that bolt.. Not to mention that the bolt was only in by about 2 threads.. I turned it and it fell it; oil fell out with it as well.
There was oil all around from underneath the bolt also.
Re: H22 oil leak (93preludeh22)
that bolt is there for when you need to line up the balance shaft timing. as long as it is tightened you should not have a problem
