B series trans question
I am having a problem with my trans and want some other opinions before I tear into it. I can shift fine 1st-5th but when I put it in reverse it doesn't want to come out of reverse. I have to litteraly beat it out. I was thinking it could be a bent shift linkage, bad pressure plate, or a bad syncro. What would be the most likly cause and fix?? Any help would be much appreciated. Thanks.
is it hard to pull out of reverse while moving in reverse?
meaning, sometimes you can just pull it out of gear w/o depressing the clutch.
Do you know what fork it would be? Fork Sub, 3-4, or 1-2?? Also, would this be something I could do myself or should I have it done? FYI I have neverdone anything more that changed the fluid and done a clutch kit. THANKS!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">reverse gears don't really wear out. My vote = bent shift fork</TD></TR></TABLE>
thats what isaid the first time
blue89hatch
Transmission & Drivetrain
Nov 24, 2008 11:14 PM
