H22 A/c Compressor in EG Hybrid?
I am going to swap in an H22 into my EH chassis. My existing D series AC compressor sounds like its clutch is going out. Since it would prolly be cheaper to buy a remanufactured H22 AC compressor and use the factory mounts than replacing my D Series compressor and buying an HCP mount, I was wondering if anyone could forsee if I will have fitment issues.
Thanks in advance.
Edit: I forgot to mention that my AC system has been completely converted to R34 already.
Thanks in advance.
Re: H22 A/c Compressor in EG Hybrid? (nikolai.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikolai. »</TD></TR><TR><TD CLASS="quote">I am going to swap in an H22 into my EH chassis. My existing D series AC compressor sounds like its clutch is going out. Since it would prolly be cheaper to buy a remanufactured H22 AC compressor and use the factory mounts than replacing my D Series compressor and buying an HCP mount, I was wondering if anyone could forsee if I will have fitment issues.
Thanks in advance.</TD></TR></TABLE>
I beleive you keep the SOHC compressor because the H22 won't fit. Are you using the HCP AC compressor mount?
Re: (nikolai.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikolai. »</TD></TR><TR><TD CLASS="quote">well i was hoping to get away from having to buy a new compressor and the hcp mount by just using an h22 compressor.
but if it wont fit, then it wont fit.</TD></TR></TABLE>
check with HCP to make sure however that is my understanding.
Re: (MrMike)
the h22 ac compressor will rub on the frame rail, cause the pully is to thick. You need have to run the d series compressor. I would have sold you my hcp bracket but I sold it last week. I am running AC on my h22 00 Si and the bracket works great. I had to modify it for a bseries compressor, but thats it. You also need a slim fan and put it on the front side of the compressor.
djsire
04-25-2006 01:56 PM
