custom breaks?
Old Mar 2, 2006 | 07:04 AM
dc2gsr96's Avatar
Default custom breaks?
i have a 96 gsr and i was wondering if it was possible to take prelude rotors i know u have to redrill them and ITR break calipers for like a custons break kit.. any thoughts on it ? i saw it in a magazine and wondered if it was possible
Old Mar 2, 2006 | 03:28 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: custom breaks? (dc2gsr96)
like the prelude 4x114.3 rotors? why not just buy a BRAKE conversion instead?
Old Mar 2, 2006 | 04:05 PM
dc2gsr96's Avatar
Default Re: custom breaks? (honda 3300)
what kind are u talking about??? and i know u have to re-drill the rotors to fit i found it in a mag some guy did it to his civic like a custom big break kit
Old Mar 2, 2006 | 05:01 PM
h23vtec_eg's Avatar
hey man it can be done for a fairly cheap prize
all you need is prelude vtec rotor and accord wagon calipers .
Old Mar 3, 2006 | 07:44 AM
dc2gsr96's Avatar
Default Re: (h23vtec_eg)
so u mean the h22 rotors and the guy i read it about used ITR calipers ... what are the offset on h2 rotors do u know b/c i have to redrill them i know that
Old Mar 3, 2006 | 05:00 PM
h23vtec_eg's Avatar
what you need to do to get them redrilled right is grab your stock rotor put it face to face with the 93 prelude vtec rotors and get a shaft thats 2.530 in diameter so that you can hold the 2 rotors centered to each otherwith the hole in the middle, then what you will end up doing is drilling the holes where the rotors are already drilled for the small phillips screws, i recomend doing this in a mill machine because the drill bit will shift on you and it will be off.
Old Mar 3, 2006 | 05:06 PM
dc2gsr96's Avatar
ok what is the shaft thing for i dont understand that my bad and what calipurs should i go with ?
Old Mar 4, 2006 | 01:01 PM
h23vtec_eg's Avatar
hey kyle i'll tell you what im a little restricted here because im new if you email me at auvatidopj@aol.com i can send you some pics of what i've done , but it does take some custom fabrication like cutting and welding new mounting tabs on the hub assembly where the calipers mount and on top of that you will need accord wagon calipers . i used 93 prelude vtec rotors 11 inches and accord calipers. i will send you some pics if you are interested .
Old Mar 4, 2006 | 01:03 PM
h23vtec_eg's Avatar
im not sure but i think the tabs on ur gsr might be longer than my 93 civicc so you might just get away with using the accord calipers and redrilling the rotors .
Old Mar 5, 2006 | 12:44 PM
dc2gsr96's Avatar
hey man i send u an e-mail
forbiddenera
Suspension & Brakes
Oct 3, 2017 07:06 PM
DuongBros.
Suspension & Brakes
Oct 18, 2008 02:04 PM
Understeer
May 1, 2006 07:20 PM
babemonster_bo
Dec 28, 2004 11:20 AM
