Please help with IACV problem!
Old Mar 8, 2006 | 04:49 PM
speedy108's Avatar
Default Please help with IACV problem!
Here is a short breakdown of everything done to the car:
93 DX Civic Hatchback
OBD2 '99 GSR Motor (2.0L)
OBD2 '99 GSR wiring harness
OBD1 P72 GSR ECU
(Already wired the Vtec and the Knock sensor)
Am I suppose to repin the wires for the IACV on the ECU connectors?
Problem-I have tested this IACV off the car to make sure it worked, so I know it's functional. When I start the car I have to keep giving it gas until it warms up or it will just die, all I get is a code 14 two seconds after start up. The connectors are hooked up in the right sensors also. Any ideas?
Thanks
Old Mar 8, 2006 | 06:16 PM
speedy108's Avatar
Default Re: Please help with IACV problem! (speedy108)
The motor also has a Edelbrock IM and TB if that makes a differance.
Old Mar 9, 2006 | 05:56 AM
speedy108's Avatar
anyone have any idea
Old Mar 9, 2006 | 01:30 PM
tha_badguy's Avatar
u have to change sum pinouts on the ecu plug...
i had to do this to my mini-me but it should be about the same for urs
just find a pinout diagram for ur ecu
its called a iacv fix...
heres one for 96-98 integ i dont kno but it might be the same if not it gives u an idea of whats involved...
Modified by tha_badguy at 2:41 PM 3/9/2006
Old Mar 9, 2006 | 04:44 PM
speedy108's Avatar
Well that is a good guess but I'm using a OBD-1 GSR ECU and the IACV pin is in A9. Any guess on what I need to do as far as repinning the IACV on my ECU?
Thanks for the help
Old Mar 9, 2006 | 10:56 PM
tha_badguy's Avatar
simple as that
theres no special trick
ur just puttin the iacv pinouts where the ecu expects them to be
Old Mar 9, 2006 | 11:45 PM
JDMC-Kamel's Avatar
Default Re: (tha_badguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">just find a pinout diagram for ur ecu
simple as that
ur just puttin the iacv pinouts where the ecu expects them to be</TD></TR></TABLE>
word
Old Mar 15, 2006 | 12:17 AM
crv-techu's Avatar
Default Re: (JDMC-Kamel)
you saved the day, this information was very helful thanks
Old Mar 15, 2006 | 02:08 PM
tha_badguy's Avatar
Im glad sumone appreciates it.
Old Mar 15, 2006 | 07:47 PM
crapanese's Avatar
either that or your iac isnt working, like you dont have the coolant lines ran to your throttle body or FITV
or you could have the plug for the iac switched with the one that looks just like it. i cant remember what it is
hope this helps
Old Mar 16, 2006 | 10:46 AM
EE_Chris's Avatar
Default Re: (crappyDC4)
You do not need to do the IACV 'fix'. The picture posted is for 6th gen Civic's that originally used a 3-wire IACV and need to be converted over to the more common 2-wire variety.
5th gen Civic's used a 2-wire IACV. GS-R's used a 2-wire IACV. OBD2 GS-R's also used a 2-piece engine harness much like the 5th gen Civic's, right?
Since you're getting the code immediately upon start up, that's a hard fault as in, something is either shorted or just not hooked up. Perhaps the IACV wire from the shock tower harnesses aren't hooked up correctly. But the wire at the ECU should be sitting in the correct spot for this swap.
Old Mar 16, 2006 | 05:43 PM
crv-techu's Avatar
Default Re: (EE_Chris)
i can't figure mine out because i have obd2 to obd1. my boomslang harness dosn't have those ports for the obd1 ecu.
SirRevvs
Feb 19, 2007 02:51 PM
CA6VTEC
Oct 3, 2006 02:32 PM
Hybrid2Be
Dec 19, 2003 03:54 AM
ozzyman
Sep 4, 2002 07:57 PM
