b20b ? with gsr head
I tried to find this already by doing a search but no luck so far. My ? is with the B20/Vtec setup do I need the knock sensor if I am going to put on a GSR head on a B20 block? Any other helpful hints about this setup other than that help me out also, so thank you ahead of time.
Pretty much I just need to know if I should go with the B20b or the B20z. I do not care about the commpresion since I would change out the internals of the block anyway.
Re: b20b ? with gsr head (tabbob7681)
you will probably have to wire up a knock sensor because a vtec ecu will throw a code with it not hooked up???i think i dont really know
luckeydog14
04-17-2005 09:22 AM
