how to check codes after swap?
hello i was wondering i did obd1 h22 into obd2 civic so how am i suppose to check the engine codes will the data link conector still work or how do i do this thank you.
Re: how to check codes after swap? (mikegeezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikegeezy »</TD></TR><TR><TD CLASS="quote">hello i was wondering i did obd1 h22 into obd2 civic so how am i suppose to check the engine codes will the data link conector still work or how do i do this thank you.</TD></TR></TABLE>
Yes, it will still work.
Re: how to check codes after swap? (SixguN)
thank you. but will the one on the driverside work the one that you use to hook up the scanning machine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikegeezy »</TD></TR><TR><TD CLASS="quote">thank you. but will the one on the driverside work the one that you use to hook up the scanning machine?</TD></TR></TABLE>
Not sure but I would think so.
well i know that obd1 and obd2 have diffrent connection when you use that tool so i dont think that it will cuz i would be trying to get obd1 code from an obd2 port
Maybe a scan tool will work maybe not. Scan tools don't work on my jdm ecu or my chipped p28. I think it has to be an obd2 usdm ecu for it to work.
