ls/vtec question
Old Mar 20, 2006 | 04:02 PM
dkk119's Avatar
Default ls/vtec question
i was wondering if you could use a gsr water pump and a type r oil pump, and what timing gear should be used with it?
Old Mar 20, 2006 | 08:54 PM
BigJ5's Avatar
Default Re: ls/vtec question (dkk119)
GSR, Type-R and B16A/B all share the same water pumps, as well as the same oil pumps...you can interchange them with the B18A/B's without issue
Old Mar 21, 2006 | 03:24 PM
dkk119's Avatar
what timing gear should be used?
Old Mar 22, 2006 | 07:55 PM
boostedblkef's Avatar
Default Re: (dkk119)
gsr
Old Mar 23, 2006 | 04:33 PM
dkk119's Avatar
Default Re: (pitbullracer)
also what other gaskets would i need to complete? i have the headgasket,im gasket, exhaust gasket, valve cover gasket.
what others and for what motor?
i have a b18a block and b16a head
Old Mar 23, 2006 | 08:51 PM
redhondacivic's Avatar
Search, I mean come on I am NEVER a guy to say "SEARCH NOOB" but I mean there are so many web-sites dedicated to LS/VTECs. And all of the B Series VTEC is transferable, the only thing you will need to run those is a VTEC timing belt, it is different than the non-VTEC one. And search for a parts list.
DirtyDA9
Oct 28, 2011 05:48 PM
silverdcteg
Mar 20, 2009 12:48 PM
93slmdcvcsi
Feb 10, 2005 08:09 AM
elusive123
Jul 18, 2004 11:06 AM
JDMvtecDRAGSTA
Aug 1, 2002 05:19 PM
