ZC Swap Wiring Help! (Pics included...)
First off, it's an SOHC ZC engine going into a 91 Std. Hatchback.
Here's my injector resistor box:
So, I'm going to list the steps I have and you tell me if they are correct! (Sounds simple enough, right?)
Step 1: Connect the two Yellow/black wires together, (the ones that were connected to the 2 DX injectors) then connect them to the Yellow/black wire on your injector box.
BEFORE:
AFTER:
Do I splice it like this? I have all four cut yellow/ black wires twisted together. Is that correct?
Step 2: -The yellow wire from the DX injector goes to Injector #1 (brown wire)
-The Red wire from the DX injector goes to Injector #3 (blue wire)
-Connect the wire you installed at A2 to Injector #2 (red wire)
-Connect the wire you installed at A4 to Injector #4 (yellow wire)
BEFORE:
AFTER:
I connect them here?
Step 3: Connect the 4 red/black wires from injector resistor box to each injector.
BEFORE:
AFTER:
Now then, that all seems OK if I have it right, but what do I do with these wires?
Do I just leave them? Take them outta the plug? Or do they belong somewhere?
And what do I do with this wire? Leave it alone?
Thanks alot!
-Tippyman
BEFORE:
AFTER:
BEFORE:
AFTER:
BEFORE:
AFTER:
Thanks alot!
-Tippyman
Tippyman
14
03-27-2006 08:55 PM
Tippyman
03-23-2006 06:40 AM
