Need Help Problem On B16 Swap
Old Apr 3, 2006 | 04:59 AM
GersWorkz's Avatar
Default Need Help Problem On B16 Swap
Heres The Deal I Just Finished My Boys swap We Put A Jdm B16a and Converted To Obd1 with A kenji Chipped ecu . The Car Idles And Sound Fine but at around 3500 hundred rpms it falls on its face . and it only does it at half throttle not full throttle .. any comments would greatly appreciated..
Old Apr 4, 2006 | 07:35 AM
GersWorkz's Avatar
Default Re: Need Help Problem On B16 Swap (GersWorkz)
bump common somebody on here has to no something that can help me out
Old Apr 4, 2006 | 07:47 AM
bluemax189's Avatar
try a regular ecu, dont need a chipped one when its all stock.
Old Apr 4, 2006 | 10:34 AM
GersWorkz's Avatar
Default Re: Need Help Problem On B16 Swap (bluemax189)
its not stock it has bbk 70mm tb,aebs intake mani ,type R header ,rsr exhaust and cat ,and inline fuel filter and msd 6al. and its not throwing and check engine light
Old Apr 5, 2006 | 07:40 AM
GersWorkz's Avatar
tried a stock ecu still doing the same thing
Old Apr 5, 2006 | 09:27 AM
TwoRedEGgs's Avatar
Check you TPS reading to make sure its correct, you can also switch out the MAP sensor or run it from a differnt location to get a more accurate reading.
Old Apr 5, 2006 | 11:05 AM
jdmcars.com's Avatar
What car (model, year) did you do this B16A swap in and conversion to OBD1?
Old Apr 5, 2006 | 02:22 PM
GersWorkz's Avatar
Default Re: Need Help Problem On B16 Swap (jdmcars.com)
its a 96 civic dx Hatchback
Old Apr 6, 2006 | 07:18 PM
GersWorkz's Avatar
bump i checked the tps readings and they are normal and i switch out the map sensor to a different lacatrion and its still doing the same thing. anybody else got any ideas
Old Apr 9, 2006 | 04:11 PM
GersWorkz's Avatar
bump i know somebody has to have some experience with the bbk throttle bodys cuz it started doin it when we put the throttle body on
randomhe12o
Apr 7, 2011 06:19 PM
JDM@sF*ck
May 31, 2010 11:59 AM
jdmeg9
Dec 14, 2006 02:39 AM
itsjdmbradyo!
Sep 19, 2006 10:25 AM
strictlyimport
Apr 12, 2006 05:11 PM
