Question: ECU's
Old Mar 28, 2006 | 02:46 PM
Top-Fuel's Avatar
Default Question: ECU's
I have a 2000 B18C5 that I'm planning to swap into my 1997 CX hatch and this is my first time tuning or any automotive work. So please bare with me;
My question is, can I use the same ecu from my hatch with this swap or do I need to upgrade or swap the ecu?? I've read some threads and some people said to swap to p28, etc. and some said its okay to use the same....this is where I'm confused.
Also I'm planning on boosting the engine in a year or two (after I learn more about it), so can I just get the Hondata S300 even though its going to be stock for now??
What would you recommend me to do?
Old Mar 28, 2006 | 02:58 PM
vtecspeed1320's Avatar
Shooting Star
Not to buy the type r motor if your gonna boost.
Old Mar 28, 2006 | 03:13 PM
Top-Fuel's Avatar
Default Re: (vtecspeed1320)
well i know but its been done before so I'll take my chances
Old Mar 29, 2006 | 06:13 AM
IHateJDM's Avatar
Default Re: (Top-Fuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top-Fuel &raquo;</TD></TR><TR><TD CLASS="quote"> well i know but its been done before so I'll take my chances</TD></TR></TABLE>
make sure its tuned well. high compression + boost = trouble if everything isn't tuned right. IMO GSR would have been a much better motor for FI. A chipped P28 or P72 would be your best bet to provide tuning options down the road.
Old Mar 30, 2006 | 08:09 AM
Top-Fuel's Avatar
Default Re: (IHateJDM)
can you explain to me what the difference is between the P28 and the P72??
Old Mar 30, 2006 | 08:56 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top-Fuel &raquo;</TD></TR><TR><TD CLASS="quote">can you explain to me what the difference is between the P28 and the P72??</TD></TR></TABLE>
p28 is a d16z6 ecu, p72 is a b18c1 ecu. The p72 can control your IAB's (secondary butterflies in the intake manifold) where the p28 doesn't. You can use an rpm activated switch with the p28 if you want, but if you don't hook up the IAB's, they will be open all the time. That will hurt low end torque some, but top end will be the same either way. A p72 will probably be a little more expensive though.
4kgst
Mar 18, 2019 02:13 PM
HBRIDER
Feb 4, 2008 08:01 PM
TRQLESS
16
Feb 3, 2008 08:05 PM
grandam
May 16, 2007 08:03 PM
Lil_Wyte
11
Feb 26, 2007 09:48 AM
