h22 civic brakes problems?
Old Mar 27, 2006 | 08:29 PM
i_eat_ROCKS's Avatar
Default h22 civic brakes problems?
once in a while my brakes give out? it goes straight to the floor? and i cant stop? its like theres no presure? it only happens once in a while. but when i pump the brakes it regains presure and it works just fine. is there anything i could do to fix it? motor? master clinder? bleeding of the brakes? maybe.. help please..
thank you!
Old Mar 27, 2006 | 08:55 PM
bump..
Old Mar 28, 2006 | 03:04 AM
Ape's Avatar
Ape
Default Re: h22 civic brakes problems? (i_eat_ROCKS)
bump for you. Sounds scary.
Old Mar 28, 2006 | 07:41 AM
morning bump!
Old Mar 28, 2006 | 09:46 AM
ej8_vtec's Avatar
Bleed ur brakes bro, you def got air in ur lines
Old Mar 28, 2006 | 01:54 PM
dapaur's Avatar
try your master cylinder also and do you know how to bleed your brakes
Old Mar 28, 2006 | 03:32 PM
skunked's Avatar
Default Re: h22 civic brakes problems? (dapaur)
sounds like the MS if your not leaking fluid.
Old Mar 28, 2006 | 10:33 PM
thanks! i just though it was with motor.
90 ef
Oct 29, 2009 12:03 PM
jasonweaver88
Jun 29, 2007 10:31 AM
mikensu
12
May 9, 2005 01:22 PM
ITR1071
May 25, 2002 02:46 PM
from_zer0
Apr 22, 2002 10:40 AM
