HELP! 97 gsr into 93 si
97 gsr engine harness
93 si firewall harness
does everything plug and play or do addition wires/pins need to be done? hope you guys can help
Re: HELP! 97 gsr into 93 si (SONIC BOOM)
Use your 93 harness and a obd1 b16 distributor. Use a chipped p28 (your stock ecu), run your knock sensor wire, swap out your o2 sensor with your 93 si one, and you will be all set. If you need your ecu chipped let me know I have a stock GSR map.
FAAST
11-09-2004 08:06 PM
