Few problems after my swap
I swapped a typeR motor into my honda del sol..after the swap everything runs good but we have a few probelms...the tach does not work(the rpm guage) everything else works...also another problem is the temperature guage doesn't either...so...rpm guage and temp guage does not work...any ideas what could be wrong? thx
Re: Few problems after my swap (1SickSol)
check for a loose wire at the ICM inside the distributor, if that is good you'll have to check the blue tach wire, and chase it to the break...it would help us to help you if you gave the year of the chassis and the motor, and whether you've got it wired obd1 or obd2 and what dizzy you are using? you can email me at Joe@ondemandperformance.com
Re: (1SickSol)
« Re: Few problems after my swap (1SickSol) « » 8:04 PM 4/4/2006 Reply Edit
good advice
good advice
i just went out and replaced the temp switch, still not working.. and i tryed running down a broken wire for the tach but no luck, there where guages in the car(oil pressure, A/F, and boost) that we took out, im wandering if maybe we pulled something loose taking those out... any more suggestions?
well i went out yesterday, went through everything and finally found the problem... the entire gaugecluster isnt working, well it had a blown fuse, but when i replaced it, it just burnt it back out.. i put a bigger fuse in there and started smoking.. now im gonna have 2 try and run down an open wire somewhere.. anyone know anything to make this easier?
evoluti0n12
10
07-30-2009 01:53 PM
Steve91
02-10-2003 07:46 AM
