Help reading PR3 ECU Code
Old Mar 24, 2006 | 11:55 AM
SI_Ro's Avatar
Default Help reading PR3 ECU Code
This is for a PR3 (OBD0) ECU.
I'm getting 2 Long and 3 Short . Is this CEL 10 (Intake Air Pressure) and CEL 13 (Atmospheric Pressure) or CEL 23 (Knock Sensor)?
Old Mar 25, 2006 | 11:36 PM
aspec101's Avatar
Default Re: Help reading PR3 ECU Code (SI_Ro)
Well is your knock sensor hooked up? Usually the knock sensor kicks in after driving for a minute or two if it is not hooked up right. You need to wire in the knock sensor yourself if you swapped a b16 into your ef.
Old Mar 26, 2006 | 11:19 AM
SI_Ro's Avatar
Default Re: Help reading PR3 ECU Code (aspec101)
yes the knock sensor is hooked up....just trying to see if i'm reading the cel right.
Old Mar 26, 2006 | 11:33 AM
SixguN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SI_Ro &raquo;</TD></TR><TR><TD CLASS="quote">yes the knock sensor is hooked up....just trying to see if i'm reading the cel right.</TD></TR></TABLE>
The cel will blink one long which equals 10, then 1 short which equals 1. So if you are getting long...long...short.short.short, that equals 23.
But, if you are getting long............and then it pauses for 2 seconds and then long...short.short.short, you are getting code 10, and 13. Thewn it shoudl repeat these codes over, and over. There will be a short pause between codes for about 2 seconds.
Old Mar 27, 2006 | 09:29 AM
SI_Ro's Avatar
Default Re: Help reading PR3 ECU Code (SixguN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SixguN &raquo;</TD></TR><TR><TD CLASS="quote">
But, if you are getting long............and then it pauses for 2 seconds and then long...short.short.short, you are getting code 10, and 13. Thewn it shoudl repeat these codes over, and over. There will be a short pause between codes for about 2 seconds.</TD></TR></TABLE>
Good tip ...thanks for your help
Old Mar 27, 2006 | 10:37 AM
SixguN's Avatar
Good tip ...thanks for your help</TD></TR></TABLE>
No problem
Kangolbrand
Aug 23, 2006 09:23 PM
oranginal
Jul 6, 2006 02:17 PM
civisaurusrex
Jul 24, 2003 05:48 AM
hybrider
Feb 21, 2003 09:50 PM
Sachmo
Jun 10, 2002 01:23 AM
