h22 swap into 98 civic o2 sensor quick question please help out thank you.
Old 03-22-2006, 06:02 PM
mikegeezy's Avatar
Default h22 swap into 98 civic o2 sensor quick question please help out thank you.
ok i did all the wireing on my engine to day except i got one question my civic had 2 o2 sensors one on the manifold and one by the cat the h22 only has one by the cat so do i just hook up the one i had on my civic by the cat or do i have to extend the wires from the old manifold 02 plug to the cat? thank you.
Old 03-22-2006, 07:50 PM
cherroneballs's Avatar
do you have emission testing in your state? if so you may want to hook both of them up and if your running obd 1 ecu it's not going to read for the secondary o2
Old 03-22-2006, 08:13 PM
mikegeezy's Avatar
ok i use the p13 obd 1 so has ne1 had to run this wire or is it taken care of already with the jumper harness. should i just leave the old primary o2 sensor alone? what im trying to say is the secondary 02 sensor that i had on my civic is that what the p13 is going to get its signal from or do i have to do some wireing?
Old 03-22-2006, 08:53 PM
it should get it's reading off the primary o2 the one before the cat and yes the jumper will take care of that. are you using a obd2 civic harness right.
Old 03-23-2006, 03:20 PM
mikegeezy's Avatar
Default Re: (cherroneballs)
yes i am using an obd2 to obd1 jumper harness. with that harness does that make my old secondary o2 sensor the primary one for the p13? i have an empty plug in my engine that use to go to the o2 sensor on the header so what im tring to say is do i just leave it like that and the cat sensor wires will do the job or do i have to cut the plug in the engine bay and run a wire all the way to the cat cuz thats where the o2 sensor is on the h22 and wire it that way?
Old 03-23-2006, 06:20 PM
blk98cx's Avatar
Default Re: (mikegeezy)
hey! in my 98cxh22 i only use one 02 sensor! i dont remember which one but i only use the one that goes before the cat! but if you want your car to pass emission legally you prolly have to hook up both
Old 03-24-2006, 01:23 PM
mikegeezy's Avatar
Default Re: (blk98cx)
cool but what plug should i use the old header one or the old cat one? wich one is going to work with the jumper harness?
Old 03-24-2006, 01:46 PM
IHateJDM's Avatar
the o2 on the header is your primary, that is what you want to run for obd1 ecu's. your p13 won't even look for a secondary, so just plug the hole in the cat so you don't have an exhaust leak and you're done.
Unphzd
10
06-26-2017 04:27 AM
Weifast
13
06-21-2010 02:19 PM
Cambocheen!
02-28-2009 10:13 AM
strongarm1731
02-26-2006 12:25 PM
turbotec
02-28-2002 03:33 AM
Quick Reply: h22 swap into 98 civic o2 sensor quick question please help out thank you.
