PR3 Automatic ECU Chip/Modification
Old Apr 5, 2006 | 06:42 AM
iakona's Avatar
Default PR3 Automatic ECU Ignition and Timing Alteration
Easy question guys: I would like to know if it is possible to modify/"chip" an AUTO PR3 ecu as it is to do to a MANUAL PR3 ecu.
obd-0 automatic ls/vtec 1991 DA
thanks
Modified by iakona at 8:15 AM 4/5/2006
Old Apr 5, 2006 | 08:10 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: PR3 Automatic ECU Ignition and Timing Alteration (iakona)
Yes, just move the r68 resistor to the r67 position.
See here
http://www.pgmfi.org/twiki/bin...anual
Old Apr 5, 2006 | 08:38 AM
iakona's Avatar
i'd like to keep it automatic, i'm trying to see if i could burn a chip to modify the ignition and timing parameters for the cams and i/m and such that i have. she's staying auto fo sho.
Old Apr 5, 2006 | 08:44 AM
mar778c's Avatar
Community Builder
Default Re: (iakona)
Woops, I mis-read your question. Yes, it is stright forward to chip a auto ecu.
Old Apr 5, 2006 | 09:21 AM
iakona's Avatar
excellent. that's what i wanted to hear. so the same kind of services offered for regular obd-0 ecus will work? no special parameters to take into account with the auto ecu because it works with the separate tcm for the transmission control.
Old Apr 5, 2006 | 11:06 AM
jdmcars.com's Avatar
Yes, it can be done (keeping auto and re-mapping). However, not everyone offers it. Most people that offer chips offer only ones that are just copied and re-burned, not truely custom chips. We do offer them for both the PR3 OBD1 or PR3 OBD0.
Old Apr 5, 2006 | 11:52 AM
iakona's Avatar
nice. you're now on my short list. appreciate the comments.
and you got PM
Old Apr 20, 2006 | 04:53 PM
jtchinoy's Avatar
Is is possible to get a ECU mod done for a 2000 civic automatic? I don't want to start another thread so I'm asking here.
Old Apr 20, 2006 | 07:43 PM
iakona's Avatar
have you done a search? obd2b ecus are not chippable like obd1 ecus are.
p.s. -- maybe start your own thread next time
Old Apr 20, 2006 | 09:26 PM
jtchinoy's Avatar
Yes I noted that, but there's also people saying that you can converter harness an obd1 to an obd2 to program it.
Old Apr 21, 2006 | 06:03 AM
iakona's Avatar
but you have an automatic. you'd have to either convert to a manual, or get one of those automatic obd2 to obd1 conversion harnesses and then get something. and if you go that far and spend that much, it may not be worth it.
Old Apr 21, 2006 | 01:34 PM
jtchinoy's Avatar
Even if I had a manual, wouldn't I have to convert OBD2 to OBD1 with a harness anyhow? If chipping/ reprogramming my ECU is within a $300 range or less it's worth it IMO.
badblackhatch
May 18, 2006 04:32 PM
egizzle8
Apr 7, 2004 06:55 PM
JMD
Mar 23, 2004 06:47 PM
6GACCORDH22
Mar 11, 2003 05:33 AM
