axle problem
Old Mar 23, 2006 | 07:50 PM
dapaur's Avatar
Default axle problem
i just got hcp egh22 mount kit put in and axles my mechanic is in newark im in the poconos close ot 100 miles so im in a bind my passenger side axle popped out i took it out figured the c clip was messed up looked fine i tried sliding it in it sitll wont go all the way in any suggestions on what i should do i get the first part of the shaft of the axle in but not the second part it doesnt sit flush any suggestions will be appreciated its a 95 eg with 95 h22 and a h23 trans also anyone running the same setup the hcp mounts do you guys have axles problems cause mine still looked like tehre at a bad angle
Old Mar 25, 2006 | 03:15 AM
SixguN's Avatar
Default Re: axle problem (dapaur)
What axles are you using?
Old Mar 25, 2006 | 06:08 AM
vtecspeed1320's Avatar
Shooting Star
This is the same thing thats happening to me. You have to get a prelude inner cv joint for the passenger side axle.
Old Mar 25, 2006 | 06:41 AM
SixguN's Avatar
Default Re: (vtecspeed1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 &raquo;</TD></TR><TR><TD CLASS="quote">This is the same thing thats happening to me. You have to get a prelude inner cv joint for the passenger side axle. </TD></TR></TABLE>
Is your swap in a ek, eg, or dc?
Old Mar 25, 2006 | 06:56 AM
Shooting Star
eg
Old Mar 25, 2006 | 07:00 AM
SixguN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 &raquo;</TD></TR><TR><TD CLASS="quote">eg</TD></TR></TABLE>
Are you using 86-89 teg axles or 90-93 teg axles?
Old Mar 25, 2006 | 07:52 AM
Shooting Star
Old Mar 25, 2006 | 09:39 AM
SixguN's Avatar
Are you sure thats for the 86-89 axles running HCP mounts? Reason I say that is I always thought 90-93 teg axles with accord half shaft, and prelude passenger side inner was more common for ek's.
Skunked is running 86-89 teg axles, prelude half shaft with driverside inner cv joint, not a passenger side. Correct me if I am wrong.
EDIT: Here is were skunked told me what my friend needed for his axle setup when I asked about my friends teg:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">the axle combo is the same as an EG for the DC chassis. I ran 86-89 teg axles with a prelude inner on the DS and a prelude midshaft (HCP mounts).
Old Mar 25, 2006 | 11:46 AM
Shooting Star
Default Re: (SixguN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SixguN &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure thats for the 86-89 axles running HCP mounts? Reason I say that is I always thought 90-93 teg axles with accord half shaft, and prelude passenger side inner was more common for ek's.
EDIT: Here is were skunked told me what my friend needed for his axle setup when I asked about my friends teg:</TD></TR></TABLE>
Ive already got it figured...
MUGEN_EG95
Jan 25, 2009 05:16 AM
ferio_boy
Suspension & Brakes
Jun 11, 2008 04:25 AM
nonvteclude
Aug 7, 2006 08:45 PM
toooslow
Dec 6, 2005 06:51 AM
penney
May 30, 2005 06:58 PM
