gsr block b20 crank
Old 03-19-2006, 05:18 PM
civicswap's Avatar
Default gsr block b20 crank
will a b20 crank fit in a gsr block or do you need to modify it in any way?
Old 03-19-2006, 05:27 PM
Novtecdohc's Avatar
Default Re: gsr block b20 crank (civicswap)
The b20 crankshaft is that same as a b18b/a.... You must use the B20b/z rods and bearings.... The oil jets in the gsr block has to be modded though
TurbodTegSfaria
10-05-2009 03:36 PM
lakai_19
03-12-2008 07:51 PM
H23vtecEG
10
01-22-2005 02:34 PM
fabshybrid
16
08-07-2004 09:27 PM
Quick Reply: gsr block b20 crank
