anyone have a B20 head gasket laying around?
Need to have the cylinder diameter measured to see if its 85mm or not. Or if anyone can confirm its size. Thanks
Re: anyone have a B20 head gasket laying around? (RTW DC2R)
Bump
My impression was other B series HGs were 1mm over std. bore (82mm). So, if a b20s stock bore is 84mm, wouldn't a B20s HG be 85mm?
for the record, just received my B20 gasket today. using a worn out metric ruler, it DOES appear the B20 gasket is atleast 84.5mm, possibly 85mm (hard to tell with my ruler).
same goes for the 81mm gasket, its actual size appears to be 81.5-82mm.
again, measuring with a ruler made it difficult to get exact reading but definitely larger to accomdate a re-bore.
someone else might want to confirm with more exact measuring tools.
