can a d15 non vtec wiring harness work with a b16 swap?
like the title says........its a 1995 honda civic hatch with a jdm b16a swap........can I use the stock wiring harness on the b16a swap, since it will be on the wrong side if I dont........if not, what other harness could I use with the swap?
Re: can a d15 non vtec wiring harness work with a b16 swap? (msinsky14)
You can reuse your stock harness or go with a EX or Si harness so you wont have to go through the hassel of wiring vtec, knock sensor, etc..
Re: can a d15 non vtec wiring harness work with a b16 swap? (0LlY)
WOW.......i had no clue that using a USDM vtec harness, then u didnt have to wire for vtec, or knock sensor, etc.........thanks a lot, if you have any more info on this please send it to me!!
hatch b16a guy
07-15-2007 08:25 PM
