vtec pressure switch
Old Mar 26, 2006 | 02:25 PM
iNERtIA's Avatar
Default vtec pressure switch
when i convert to obd1 from obd2b its throwing a code for pressure switch which wont activate my vtec but the problem is i ONLY have a vtec solenoid. i DONT have the pressure switch but i have no codes wen i use my stock obd2 p72
thanx!
Old Mar 27, 2006 | 10:03 AM
iNERtIA's Avatar
ttt
Old Mar 27, 2006 | 01:44 PM
f2m0u5's Avatar
Default Re: vtec pressure switch (iNERtIA)
You need to get a pressure switch.. it wasnt on your harness from the obd1 motor?? weird, you have the vtec solenoid plug but not the plug for the pressure switch correct?? what kind of car did you swap the motor into btw, would help out alot
Old Mar 27, 2006 | 01:57 PM
Fobtions's Avatar
Default Re: vtec pressure switch (0LlY)
just splice the vtec pressure switch wire into the solenoid wire.
this is what i do to all swaps that do not come with the pressure switch.
or u can ground the pressure wire also.
Old Mar 27, 2006 | 06:16 PM
iNERtIA's Avatar
its a jdm b18c. i believe they did not come with it. jdm ecu only needs the solenoid for vtec to engage.
im running a usdm p28 so its looking for the pressure switch.
ur saying just ground the pressure wire from the ecu or tap it with the solenoid?
Old Mar 27, 2006 | 06:24 PM
f2m0u5's Avatar
Default Re: (iNERtIA)
well with my JDM swap i have, i had both vtec pressure switch and vtec solenoid plugs.. i wired both to the ecu and plugged them in. The VTEC pressure switch has two wires coming out of it, wire 1 to the ecu and the other is a ground wire. But supposely JDM motors dont have vtec pressure switches, so I think your suppose to pin it to your ecu and ground it somewhere. Ill try to find out and let you know
*edit* you can either ground the vtec pressure switch or tap it into the vtec solenoid wire
Old Apr 3, 2006 | 09:42 PM
iNERtIA's Avatar
i tried tapping and grounding it with the solenoid on the frog harness but it ddnt work. am i supposed to cut the switch wire then jump it?
Freya Franco
Engine Management and Tuning
Dec 13, 2017 10:49 PM
skoodles2k6
Apr 14, 2008 07:29 PM
Outkast95LS
Jun 3, 2007 07:58 PM
VXdreamer
Mar 2, 2003 12:49 PM
The Mole
Dec 17, 2002 12:52 PM
