FRONT END EARTHQUAKE
Old May 23, 2006 | 11:16 AM
Pojazz's Avatar
Default FRONT END EARTHQUAKE and vss
99 b16b swapped into my eg hatch. ive been driving the car for about a year now recently i put new pads on the front and a day later the front end shake was horrable from 45-55 to stop. turned the roters and it went away now today coming home from work the front end started shaking again a little worse then before. rebuilt the calipers and greased, check all suspesion components everything seems to be in order nothing loose as bushings shot maybe a tear here and there the car has all oem parts except what i needed for the swap.?also i recieved a vss dont know what it was from but it finally went out one of the pins on the sensor broke off. bought a new one for a 99 si pluged it in doesnt work, warrented for a new one still doesnt work are the signal wires in a different position on the sensor it self i believe the harness im using is fromm 99 ex with a few wires added.
mr arizonas pop
Jun 16, 2012 05:59 PM
nolakid504
24
May 30, 2009 03:04 PM
parasonic
Feb 16, 2007 12:17 PM
mistaxjimbo
Sep 26, 2004 08:14 AM
kamira
Dec 10, 2003 03:47 PM
