NEED HELP!!!!
Old May 22, 2006 | 04:49 PM
civicguy81's Avatar
Default NEED HELP!!!!
I have a 98 civic Ex (or a Si Canadian) and I just dropped in a 94 LS b18b1 we r tryin to do the wiring and cant figure out some of the plugs, the biggest concern is the 7 wire plug (LS) to my 8 wire plug from the Si harness and then some of the other wires as well like the alternator on the LS is a big green round thing compared to a rectangled plug on the d series, should I just change the alternators? and injectors, the LS plugs have a tab that is in line with the injectors while the harness is off set, should I splice the new injectors on cauze the LS injectors are a higher fuel or should I just change the injectors cauze its the same?I have some more but im not to sure yet but the MAIN one is the 7wire plug to the 8 wire plug
thanks
Stu
Old May 23, 2006 | 03:33 PM
civicguy81's Avatar
ttt
crist488
Sep 4, 2009 04:09 PM
nellified
Nov 27, 2008 06:03 AM
jgrogan
Jun 10, 2008 01:30 AM
91lude
Dec 17, 2001 12:51 PM
