parts missing?
Old Jun 2, 2006 | 12:41 AM
baby type r's Avatar
Default parts missing?
I am new to this forum but have built my share of tuners. I am in the middle of a baby type r build. I have a gsr block with a ported and polished, 3 angle valve job, b16 head. I bought the block off ebay and didn't have all the parts with it. I have purchased most of the parts but not sure what goes in the hole just to the right of the oil filter. I messed up another block bu putting a freeze plug in it and broke the block. Does anybody have an answer as to what goes in that hole. I am in Iraq right now and am trying to get the rest of the parts I need for my build home so when I get back I can finish it all up.
Old Jun 2, 2006 | 09:26 PM
civicguy81's Avatar
isnt that were the oil pressure sensor goes? dont quote me cauze im not 100% sure
Old Jun 2, 2006 | 10:18 PM
Default Re: (civicguy81)
I don't think it is a oil pressure sensor I think that goes on the other side of the oil filter. The hole I am refering to is about the size of a half dollar in diamiter. I know something has to go there but not sure what. The hole leads down into the oil pan so something really does have to go there just don't know what.
Old Jun 3, 2006 | 04:35 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: parts missing? (baby type r)
That hole is where the stock oil catch can is supposed to be. There should also be a fitting right above it for the upper hose.
Old Jun 3, 2006 | 05:27 AM
Default Re: parts missing? (NVturbo)
Hey man thanks for the help. After doing a little more research i thought that was what it was. Thanks for the help.
Old Jun 3, 2006 | 05:45 AM
NVturbo's Avatar
O.G. triple O.G.
anytime.....
Old Jun 4, 2006 | 02:13 PM
Essenar83's Avatar
Yep, seconding what NVturbo said, and be safe in Iraq man.
Let us know how the build turns out
Old Jun 4, 2006 | 09:13 PM
Default Re: (Essenar83)
Once again thanks for the help, and appreciate the support for us over here in Iraq. Here is a quick list of what I have done right now for my build. I currently have a ls/vtec in the car, well almost in the car. It has type r pistons on factory ls rods and crank. Ported and polished b16 head, with a 3 angle valve job, jun dual valve springs, titanium retainers, ported manifold and throttle body, with STR cam gears, a JUN 4 to 1 header with JIC titanium exhaust.
RIght now I am working on a gsr block. Forged rods, je 11:3:1 compression pistons 81.5mm, eagle crank( or balanced and knife edged ls crank), I may get it sleeved not sure right now. I am also upgrading to buddy club spec IV cams and cam gears, an ITB set up, with the hondata s300. So far thats what I am planning on for my build. Not sure what kind of HP I will be pushing but once I get it all together and tuned I will post some numbers and let you know how the build turned out.
Once again thanks from Iraq
Old Jun 5, 2006 | 01:30 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (baby type r)
DONT FORGET SOME PICS...of the build-up..
Old Jun 6, 2006 | 03:07 AM
Default Re: (NVturbo)
Oh no doubt about the pics once I get back from this hell hole and start on the build again
smileycvc
Mar 30, 2007 10:09 PM
baby type r
Jun 1, 2006 10:08 PM
8o8da9speed
Nov 8, 2004 10:05 PM
FSTASNTZ
Dec 29, 2003 10:56 AM
MeanGreenEG9
Jan 13, 2003 01:40 PM
