93 ex harness/97 USDM h22 <----how to wire dizzy and coil?
aight fellas tony needs sum help..
im putting a 97 usdm h22 into my 92 eg...im using the stock eg harness, and the US h22 dizzy with an external coil...
first off how do i wire the eg harness to the h22 dizzy (by using the h22 clips)
second how do i wire up the coil?
thanks guys
thanks guys
the 97 dizzy is obd 2 i assume?
does that motor use a crank sensor? if so i would just find a obd 1 h22,h23 dizzy and that would solve that problem same plugs and all..
to wire up the coil there are 3 wires going to it 2 power and one idk what it is lol..
but one should be yellow and black just like on the power plug going to the dizzy. cut that wire in half and leave some space for your plug with some wire left on the end of it.. then hook up from the coil the yellow and black to the harness and the other thick wire should be yellow or white.. hook that up to the wire sticking out of the plug.. then for the little skinny wire.. you will notice on the other dizzy plug that there is a pin missing.. from the Eg harness.
what you need to do is get a pin from a another harness and put it that hole or you can tap the wire right next to the dizzy w.e you want .. and thats all
Re: (hybridpatient95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridpatient95 »</TD></TR><TR><TD CLASS="quote">the 97 dizzy is obd 2 i assume?
yah i know ive been looking for a jdm h22 one for some time now, and the 97 does have a crank sensor
