F22A Crank Pulley on a H22A (searched)
Also posted in the Prelude forum but not many answers there either, Havent had a definative answer to this as yet but any conversionists out there who converted a F22A accord/lude to a H22, did you use the F22A crank pulley for your accessories?
Reason i ask is i want to use my F22A PS/AC/Alt. but the belt and pulley is a 4 rib where as the crank pulley on my H22A is a 5 Rib. Can I swap the F22A one onto my H22?
Also thought i'd ask, is the H22a crank pulley a balanced pulley? Mine ahsabout 5 holes drilled on one side i was wondering if this might preclude me from using the F22A one which hasnt got the holes.
Cheers
Mark
Cheers
Mark
Banned.
Re: F22A Crank Pulley on a H22A (skinnyboy)
The h22a crank pulley slides on the F22A fine matches up you need to use the F22A bolt though if you using the F22A crank...
pcguy760
05-03-2007 09:29 PM
