Quick question about IAB's
Old May 26, 2006 | 06:16 AM
JasonST's Avatar
Default Quick question about IAB's
Ok quick question, I just finished up my h22 swap and wired in Vtec and my IAB's and as soon as I wired in my IAB's I noticed when I turn my key to on but not start the car, the IAB valve slides back, I'm not sure if this is off or on, but then when I take the key out it slides back and makes the vacuum popping noise. Is this normal? Or is it suppose to only happen around 5000 rpm? Thanks for any help!
Old May 26, 2006 | 06:35 PM
JasonST's Avatar
Default Re: Quick question about IAB's (JasonST)
Bump, cmon somone's gotta know.
Old May 26, 2006 | 06:51 PM
2fast4u831's Avatar
I'm really 2slow
it should be open at lower rpms
Old May 26, 2006 | 07:18 PM
Jago's Avatar
the iab should be closed at idle when you get around 4900rpm the control valve opens and releases vacuum and then a spring in the iab plate opens the valve
Old May 27, 2006 | 06:46 AM
JasonST's Avatar
Default Re: Quick question about IAB's (Jago)
So is mine messed up? Mine seams to open I think as soon as I turn the key on but not the car. I assume it's opening although I don't know for sure, it's switching forward and make a popping noise I assume is the vacuum pressure, is it suppose to do this? Is this closed or open? Anyone else's switch over when u turn the key on? Thanks for the help.
Old May 27, 2006 | 10:35 PM
Jago's Avatar
I know whats happening when the car is off there is no vacum applied so the plates are open. when the car starts it produces vacum and its not opening its realy closing the plates. when the car is off the bypass will always be open. sounds like it is working exactly as it should
Old May 28, 2006 | 07:43 AM
JasonST's Avatar
thanks Jago, that's excactly what I was looking for and you answered my question,
mccordelectric
Oct 18, 2010 08:56 AM
MyLilCivic
Nov 10, 2006 09:20 PM
TranspeedMotorsports
Nov 6, 2006 03:17 AM
1999gs-r
Oct 20, 2004 06:25 AM
MrEg
Oct 13, 2003 04:51 PM
