hasport ek k20 wire harness need help ASAP - wire identification
1st I want to state this is basically the first wiring harness made by hasport for ek k20... 3 relay harness (i bought used)
THIS HARNESS IS VERY DIFFERENT FROM THE ONE THEY'VE BEEN SELLING
included no relays...regular relays don't work
I need to know what the grey wire is for
Re: hasport ek k20 wire harness need help ASAP - wire identification (_adirondackR_)
Hey sup man. I believe you had called me earlier or someone from the shop did.
Well that grey wire is not a wire that was included in that harness. I can tell by how that wire is zip tied to the harness and also since the wire is a different gauge that the other wires. Where does the other end of that grey wire go to?
Also all the wires we use in our harness is factory colors, there is no solid grey wire for the K series conversions.
Also judging by the wires used in the E plug you have in the picture this is NOT the first HASPORT K series Sub Harness. This is one of the older harnesses yes, if it had 3 relays.
I can also tell that the harness has been tampered with, that portion of the harness is taped up and is done so all the wires are held really tight.
One of the many problems with buying a used K series Subharness, you never know what the previous owner was doing to it for thier cars.
I'm glad to hear that the car runs now. If there any problems please feel free to call us anytime here.
What relays did you use to get the car running? Did you get the new relays we discussed?
Modified by JDMjames at 11:37 AM 5/30/2006
Re: hasport ek k20 wire harness need help ASAP - wire identification (JDMjames)
pm from "honda garage" original purchaser
grey wire i believe is the tach and speedo wire....when i bought this harness from hasport, a few things were in the wrong position...I bought the harness for a 99 ex, and i believe i got a 96 ex that needed to be modified...If car starts and tach doens't work then that is your problem..Call me 323 547 5113 i won't be onlinem
ok the shop bypassed all the relays on the hasport adapter harness (i dunno if o2 will work)in order to get car to run but is this bad - can't I eventually fry the K-pro
need help trying to get relays to work...supposed 30amp hella relays.
edit to hasport & brain_g - he's on the phone with my shop as we speak
Modified by _adirondackR_ at 1:18 PM 5/26/2006
