ITR into a EK hatch
Old Jun 4, 2006 | 01:41 PM
autox228's Avatar
Default ITR into a EK hatch
I just bought a 96 itr swap. i also purchased the hasport mount kit & and shift linkage. what other parts are need to complete this swap? note that this is my first time doing a motorswap. i just need more info. i've searched thru the archives and find a lot of threads about other swaps but they dont tell me what parts i need to fulfill this swap. Do i have to upgrade anything too? BTW i have a 96 CX hatch.
Old Jun 4, 2006 | 01:46 PM
autox228's Avatar
Default Re: ITR into a EK hatch (DB8_228)
yes im retaining a/c and ob2-a too.
Modified by DB8_228 at 11:12 AM 6/5/2006
Old Jun 4, 2006 | 02:46 PM
Essenar83's Avatar
You need the rear motor mount/bracket from a 99-00 SI. You can buy this from a Honda Dealership for like 60 bucks I heard.
Old Jun 5, 2006 | 07:39 AM
autox228's Avatar
Default Re: (Essenar83)
is that what holds up the mount right?
Old Jun 5, 2006 | 09:59 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (DB8_228)
You will most likely need USDM ITR throttle linkage and mount bracket (at the manifold). Those parts are about $30
If your CX has the catalytic converter on the front of the engine, than you will not be able to reuse it (outlet is angled). You will have to get an integra or aftermarket cat & have it added to your exhaust.
Radiator hoses will need to be integra upper & 99-00 Civic lower (I think).
You will probably want a larger radiator (99-00 Si I'm guessin).
Wiring will be wierd since your engine harness is part of the main wire harness...
Old Jun 6, 2006 | 04:24 PM
autox228's Avatar
Default Re: (94eg!)
i heard there's suppose to be another bracket for the side near the timing belt. you guys know what the part # or name is? im trying to get all this gathered before i do the swap.
Old Jun 6, 2006 | 05:25 PM
beak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB8_228 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 96 itr swap. i also purchased the hasport mount kit & and shift linkage. what other parts are need to complete this swap? note that this is my first time doing a motorswap. i just need more info. i've searched thru the archives and find a lot of threads about other swaps but they dont tell me what parts i need to fulfill this swap. Do i have to upgrade anything too? BTW i have a 96 CX hatch. </TD></TR></TABLE>
http://www.phear7imports.net/subs/btroop/trey/6gen
doosua
May 5, 2018 09:07 PM
Saf
Jan 21, 2017 10:50 AM
Radyjr
Sep 27, 2004 08:06 AM
CallmeLuke
Nov 28, 2003 10:12 PM
BLK JDM
Mar 17, 2003 11:34 AM
