F22b1 with h22 crank/rods ???
* B A N N E D *
1 Post
I am gettin ready to build an f motor, and heard that I can use an h22 crank (with the 50mm journals), and H22 eagle rods with f pistons....anyone know what im talking about, and if you do, is there anything else i need to know about if this will work ??
Thanks.
Thanks.
Re: F22b1 with h22 crank/rods ??? (bigdaddyvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdaddyvtec »</TD></TR><TR><TD CLASS="quote">I am gettin ready to build an f motor, and heard that I can use an h22 crank (with the 50mm journals), and H22 eagle rods with f pistons....anyone know what im talking about, and if you do, is there anything else i need to know about if this will work ??
Thanks.</TD></TR></TABLE>
yes this will work fine, you can use the h22 crank and rods , with your f22 pistons. your going to want to calculate out the compression ratio though, with less stroke and the compression height difference of the f22 pistons verse the h22 pistons the compression will be pretty low. i would recommend boring out the f22 to 86 and then using rsx pistons to get a higher compression ratio..
also so you know the h22 head fits on the f22, check my sig.
Im runnin FORGED wiseco pistons in my F22b1!! With a .20 overbore!! Bitch is gonna be fast! The reason bein able to use Forged with the F22 block is cause the sleeves are stock Iron!!
