b20 vtec question
Old Jun 5, 2006 | 03:11 PM
Jerod's Avatar
Default b20 vtec question
i was curious about something...I have a b20 vtec in my integra just put it together. i have skunk2 im, dc header, apexi exhaust, 11.8:1 compresion (JE pistons), eagle h beam rodes, fully ballanced (rods, pistons, and crank) bored 20 over, golden eagle block guard, my car sounds like a chevy pickup (lopes) is that normal? It doesn't seem to be running bad at all. Just curious
Old Jun 5, 2006 | 06:46 PM
Jerod's Avatar
bump
Old Jun 6, 2006 | 08:07 AM
Jerod's Avatar
Default Re: (Jerod)
ttt
Old Jun 6, 2006 | 07:02 PM
Jerod's Avatar
Default Re: (Jerod)
anyone
Old Jun 7, 2006 | 02:21 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: b20 vtec question (Jerod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jerod &raquo;</TD></TR><TR><TD CLASS="quote">my car sounds like a chevy pickup (lopes) is that normal? It doesn't seem to be running bad at all. Just curious</TD></TR></TABLE>
sounds normal. depending on cam overlap (where you have your cam gears set) you will get a rough idle. my car does the same thing with toda b's.
Old Jun 7, 2006 | 06:29 AM
Jerod's Avatar
stock cams and cam gears
Old Jun 8, 2006 | 09:10 PM
vw eater's Avatar
what head are u using?what timing belt are u using?just asking becuse iam buildingone and dont know what timing belt and what head gasket gsr head on b20b?thanks
Old Jun 9, 2006 | 03:51 AM
Jerod's Avatar
Default Re: (vw eater)
i have a gsr head on b20 block using the gsr timing belt and oil pump and the head gasket i got is made for the swap. go to lightningmotorsports.com they should have what you are looking for. What pistons and rods you using?? because i have JE Pistons and Eagle rods. the bolts in the bottom of the rod prevents you from putting the plate in that stops the oil from slushing around when the rods go up and down. Golden eagle makes a modified one you may want to think about getting if your going with the same set up.
Old Jun 9, 2006 | 04:30 AM
bks84's Avatar
Loved
what EMS are you using?
Old Jun 9, 2006 | 07:51 AM
Jerod's Avatar
Default Re: (4sd4dr)
chipped p28 running chrome pro it's not really tunned right now. I did the auto-tune and richined it up some. i'm trying to get some people out here to rent a dyno for the day so we can dyno tune.
Old Jun 9, 2006 | 12:39 PM
bks84's Avatar
Loved
get it tuned, then ask questions.
em1pusha99
13
May 7, 2010 09:06 AM
agordon
Nov 26, 2006 05:02 AM
SuperImport
Apr 12, 2005 04:44 AM
allnapower
20
Dec 21, 2004 06:19 AM
barney 93
Jan 3, 2004 12:11 PM
