ABS light on, but won't blink!
So I recently put in an h22 into my teg and notcied that now the ABS light is on, well I know that it's suppose to blink if you jumper the ecu connector, I did that, and the ABS light comes on, then turns off, no blinks at all, but when I un-jumper the connector then the ABS light just stays on forever. Please help, any help is greatly appreciated.
Re: ABS light on, but won't blink! (JasonST)
I would reset the ABS control unit and drive the car. If the light returns you know there is a real prob, not just a false alarm. To reset remove the abs unit fuse in the small ABS fuse box for 15 seconds and test drive. HTH
Re: ABS light on, but won't blink! (EG civic)
Yes I made sure the axles had ABS rings, they're DSS axles, as for the ABS motor, I've unplugged the battery and left it overnight and came back many times as every time it's always on. Any more help would be appreciated.
siblue_gzer
08-13-2007 12:17 PM
