my h22t wont boost
my h22t wont boost
well my car has a very very weird problem wich i cant figure it out.well its a h22t on an ek.well the car will only boost 10psi thats it has a 60-1 garett turbo.i have cheked the charge pipe with 20psi air presure no leak took of intercoler no leak,chage wasegate still the same and the wasegate has a 14psi spring,change blow off valve same,change intake had golden eagle put stock same,change my racing cam gears to stock same,cheked timing on dot,chage boost gauge same ,remove vacum line from wase gate lef it open,still 10psi,cheked compresion on engine 150 across has 8.5 piston,cvhage turbo to a brand new 60-1 same,has a 3bar map sensor change it try another one same,this car is pissing me off already,if some one have any sugestion on what can it be ill apreciate it.
