lsvtec in an ek, need questions about specific parts to fit in. please help
ok, i have done lots of research and need a few things cleared up. i beleive i have the right idea, but i'm not sure. i was planning on dropping my obd1 motor in an si eg, but due to having my car stolen, i now have to fit it in a dx ek.
my first question is do i need an ac bracket from a b16 si to fit it in there, or will the integra one work?
and i plan on getting a chipped p28, and i was wondering what wire harness i need to purchase. (i know i could modify the dx one, but it was cut real bad and def needs to be replaced altogether) so which harness will make this process the easiest? (also, i already have an obd1-obd2 converter harness if that helps)
and one last thing. i'm using a gsr head with a shunk2 manifold and i changed the throttle pulley to an ls one. i'm looking and my throttle cable is also on the verge of snapping and i would like to get that replaced. but i'm not sure if i can just get another dx one, or would i need one from a 99-00 si or 92-95 vtec or 94-01 vtec.
any help is GREATLY appreciated.
thank you so much HT!
ac bracket for si civic harness if 96-98 get one for ex 99-00 still the same just get a harness for same year as your car..throttle cable i guess just get one for a 00 si
Re: lsvtec in an ek, need questions about specific parts to fit in. please help (SrT4u2nV)
so would a b series compressor work with the crv ac bracket?
im not sure on that. if you go that way you will have to change your lines, like have them welded.
terronb20ek
18
04-02-2011 04:34 PM
