h22 eg mount question
I have a big vibration under decel I noticed after I put the H22a in the car. Well to come find out the engine wasn't sitting level, the passenger side was sitting really low. The engine would raise up like 2 inches on the passenger side under accel and come up to where its suppose to be, the vibration stoped under accel. I have the hasport mounts I believe they are the EGH1 mounts, I bought them off of a friend. I raised the transmission up to where its suppose to be and tightend the mount on the trans, seems to be level now. I was wondering how many bolts do you guys have holding the plate to the transmission for the mount. Here is a picture of mine:
Re: h22 eg mount question (makelove2hondas)
Well i have hcp mounts. I guessing they would all be the same since there all roughly close in design for bolting it on the engine itself. The hcp mounts use 3 bolts on the transmission to hold that bracket. hope that helps
Re: h22 eg mount question (lak8)
its suppposed to be bolted with three bolts.From the looks of it,u could have certain accord transmission where one of the bolt holes won't line up.Ive seen this happen before.
Re: h22 eg mount question (aeolus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus »</TD></TR><TR><TD CLASS="quote">its suppposed to be bolted with three bolts.From the looks of it,u could have certain accord transmission where one of the bolt holes won't line up.Ive seen this happen before.</TD></TR></TABLE>
yup three bolts, although i utilize an accord bell housing and don't have an issue
if its a prelude tranny,there should be some threads,if not,its a good chance the hole wont line up.whats the code on your transmission?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makelove2hondas »</TD></TR><TR><TD CLASS="quote">nobody eh?</TD></TR></TABLE>
is there a threaded hole in the tranny that lines up with the hole on mount?
all prelude trannies will ahve bolt holes to match those 3 holes in the mount.
92-93 accord trannies will have a hole that needs ot be tapped right there, while 94 accord up trannies will have a threaded hole there.
90-91 accord trannies will have no hole there at all.
if you got an m2XX tranny then the case has been swapped if it doesnt line up to a threaded hole.
Re: (v4lu3s)
it lines up to a hole in the case but i can't see down in there good enough to see threads, partlly because of the clutch fluid line brack is right above it, i even tryed to move it. do you know the right size bolt, I could just try threading one down in there? thanks
