b18b==b18c for swap into 1993 civic dx
I want to swap a b18b into my civic however i can't find out what parts i am suppose to swap with the engine. Is it all the parts you would swap with a b18c?
be professional
Re: b18b==b18c for swap into 1993 civic dx (fcrx7zoomzoom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcrx7zoomzoom »</TD></TR><TR><TD CLASS="quote">I want to swap a b18b into my civic however i can't find out what parts i am suppose to swap with the engine. Is it all the parts you would swap with a b18c?</TD></TR></TABLE>
Everything is exactly the same except for the wiring and ECU. With the B18B, you dont need to wire in the VTEC, IAB, or knock sensor because the B18B has none of those - basically, you won't need to do any wiring. You'll need an OBD-1 P75 ECU.
Re: b18b==b18c for swap into 1993 civic dx (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Everything is exactly the same except for the wiring and ECU. With the B18B, you dont need to wire in the VTEC, IAB, or knock sensor because the B18B has none of those - basically, you won't need to do any wiring. You'll need an OBD-1 P75 ECU.</TD></TR></TABLE>
exactly.
exactly.
Re: b18b==b18c for swap into 1993 civic dx (NRZero)
just use everything from the integra
motor, tranny, mounts, wirng, shift linkage, axles, headers, intake manifold and throttle cable.
if its a 96 and up , then you are going to need a 0bd-1 p75
