ls/vtec
Old May 22, 2006 | 04:37 PM
95_red_dc's Avatar
Default ls/vtec
i have b18b with stock internals and i was seeing if anyone on here has done a ls/vtec setup on stock internals and how it went how long it lasted, and did it make a big differance putting a vtec head on and opions
on doing the head swap was it worth it thanks and yes i know i should search
Old May 22, 2006 | 08:10 PM
lsvtecSIrex's Avatar
SEARCH!!! there's a million things on this, i just did my lsvtec.
yes its a huge differance, i wouldnt recommend stock internals, arp rod bolts and head studs atleast. people say u need a vtec oil pump and water pump (with gsr timing belt) but i dont think its necessary. higher compression pistons would be better too
Old May 22, 2006 | 10:07 PM
Dat1BVtecN's Avatar
Default Re: (lsvtecSIrex)
it all depends on the head your using and etc. yes its worth it, youll be gettin a little bit more torque due to the ls crank and rods but i would get some high comp. pistons. I wouldnt recommend going LS/Vtec if you dont know wtf your doing and new to the game.
Old May 22, 2006 | 10:49 PM
95_red_dc's Avatar
Default Re: (Dat1BVtecN)
i shouldent be to hard if i am able to do a motor swap i can do a head swap
Old May 22, 2006 | 11:10 PM
Dat1BVtecN's Avatar
Default Re: (91cleancrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91cleancrxsi &raquo;</TD></TR><TR><TD CLASS="quote">i shouldent be to hard if i am able to do a motor swap i can do a head swap</TD></TR></TABLE>
WOW motor swaps are easy haha ya think, if u think thats all it takes to do LS/VTEC is to switch over the head than search is your friend idiot. your gonna have to tap and plug a hole under the head, also your gonna need to go get your seld a good oil line kit(golden eagle) plenty other stuff go search idiot and dont argue with me, i built a LS/VTEC before so i would know noob
Old May 23, 2006 | 02:14 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN &raquo;</TD></TR><TR><TD CLASS="quote">WOW motor swaps are easy haha ya think, if u think thats all it takes to do LS/VTEC is to switch over the head than search is your friend idiot. your gonna have to tap and plug a hole under the head, also your gonna need to go get your seld a good oil line kit(golden eagle) plenty other stuff go search idiot and dont argue with me, i built a LS/VTEC before so i would know noob </TD></TR></TABLE>
^^ i think this is the reason many LS/Vtecs never make it...
make sure you research this swap in detail before you attempt... not as easy as it seems (as you'll soon find out)
Old May 23, 2006 | 11:23 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (thahuhstunna)
An '06 calling an '05 a n00b...that's comedy right there. Honestly, https://honda-tech.com/zerosearch is your best friend. If I were you, Iwould just pay to have it done. It's really not as easy as it looks
Old May 23, 2006 | 11:28 AM
Dat1BVtecN's Avatar
Default Re: (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">An '06 calling an '05 a n00b...that's comedy right there. Honestly, https://honda-tech.com/zerosearch is your best friend. If I were you, Iwould just pay to have it done. It's really not as easy as it looks</TD></TR></TABLE>
ummm like i told this other guy, I've been here since like 03 using my friends name Handa, jsut because u dont know nuttin
Old May 23, 2006 | 11:34 AM
black_EM1's Avatar
Community Builder
I do know something. I know how to spell and use grammar correctly. It's cool, though, Iwas just messing with you.
Old May 23, 2006 | 02:25 PM
R.and.Y's Avatar
Default Re: ls/vtec (91cleancrxsi)
it doesn't hurt to search a lil. BUT like the other guys said it's not just taking off the ls head and installing a vtec head, that's just the main point of an lsv. Before you do the swap (if you're going to do it yourself) go get a helms booklet and dont reuse old vital neccessary parts like waterpump, oilpump, timing belt, tensioner, etc. click on "search" and type in lsvtec!
Old May 23, 2006 | 03:43 PM
95_red_dc's Avatar
ok iwas just asking some opions on doing ls/vtec and how it went , and how much better it was, how good it ran and i did not mean that doing a motor swap was easy i have done my research i know what to do when you do ls/vtec but instead i just get some jackass comments thanks
Old May 23, 2006 | 05:40 PM
5lugSlug's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91cleancrxsi &raquo;</TD></TR><TR><TD CLASS="quote">but instead i just get some jackass comments thanks </TD></TR></TABLE>
welcome to honda-tech
Old May 23, 2006 | 06:20 PM
boostedblkef's Avatar
Default Re: ls/vtec (i need a new username)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i need a new username &raquo;</TD></TR><TR><TD CLASS="quote">
welcome to honda-tech </TD></TR></TABLE>
lol true
Old May 23, 2006 | 08:08 PM
Default Re: ls/vtec (pitbullracer)
update?? what have you found and what are you still looking to learn?
butterbeer2fd
Jan 30, 2019 11:22 AM
95_red_dc
May 30, 2006 07:53 PM
No
Mar 18, 2004 03:17 PM
lsvtecrocket
Aug 4, 2003 06:14 AM
RSZero1
Nov 19, 2002 06:18 PM
