Distributor wiring question
Old Jun 4, 2006 | 03:31 PM
boost_guy's Avatar
Default Distributor wiring question
I'm trying to verify that I have my distributor wired correctly.
https://honda-tech.com/zero...14143
Would the diagram at the bottom of this page be correct for an obd2 b18c1 distributor? I just need to know if the locations of the wires are correct on the plug on the left of the diagram.
Old Jun 5, 2006 | 02:27 PM
boost_guy's Avatar
Default Re: Distributor wiring question (boost_guy)
I just need to know if the obd2 distributor plugs are the same for a b18c1.
Old Jun 5, 2006 | 09:36 PM
boost_guy's Avatar
Well I figured it out. I got a wiring diagram off of this site and it was wrong. The diagram above is correct. I rewired my distributor and the car still wouldn't start, I knew from previous tests that my main relay might've been bad. So I replaced it and it fired right up. No codes and it runs great.
Ls-v Da Teggy
Sep 27, 2014 10:54 AM
PrecisionH23a
Jul 22, 2006 07:20 AM
