Tps problem plz help!
Old May 26, 2006 | 06:34 PM
JasonST's Avatar
Default Tps problem plz help!
So I'm almost done swapping my h22 into my teg and this is the last annoying thing to fix. i'm getting CEL 7(tps) and I've checked everything, sensor is fine. Voltage is .3 volts at idle and 3.3volts at WOT, which is wrong but no matter which way I turn the tps I can't get it to spec. And then I checked the connectivity of the 3 wires from the connector. And the 2 wires on the side of the TPS both seem to be grounded to each other, using a multimeter I found this out. Are they suppose to be like this? I don't think so just trying to check, any help would be great for a change, seams like my questions never get answered on H-T anymore.
offspringpunk14
Jan 17, 2010 09:53 AM
dointhemzs
Sep 2, 2008 05:07 PM
JasonST
Apr 17, 2007 07:13 AM
TeknikDC2
Mar 6, 2005 06:30 PM
d!zZy
Dec 10, 2003 04:20 PM
