h22a eg6 CEL
Old Jun 4, 2009 | 10:23 AM
chrisfisher's Avatar
New User
Default h22a eg6 CEL
Hi,
I have a eg6 with h22a 1994 prelude conversion. I have a CEL but it only comes on when driving under load, mainly between 2500-3000rpm. If i turn the ignition off the code clears which makes it hard to find out what it is using flash codes. As soon as the light comes on it goes into limp mode.
I also have an exhaust rattle which only seems to happen once the light has come on but i dont have any heat sheilds, its de-catted etc.
Does anyone have any idea on what this could be?
Old Jun 4, 2009 | 12:22 PM
92civlude's Avatar
Default Re: h22a eg6 CEL
You probably have the backup/memory circuit "switched hot". It should be "hot at all times". Have you tried jumping the service check connector with the MIL on?
Old Jun 4, 2009 | 12:29 PM
New User
what do u mean about backup memory circuit "switched hot"?
i will try 2moro stoping the car while its on and do a check !
also red about the h22 vti lump doesnt run a nock sensor thats why the light *** on , but that shoundnt be a problem due to useing the right ecu
Old Jun 5, 2009 | 09:06 AM
New User
done the check 2day and came up with this
12) EGR (Exhaust Gas Recirculation) -Defective circuit or unplugged/ Defective sensor
23) Knock Sensor - Defective circuit or unplugged / Defective sensor
but the light is not on when the car first starts up ????
can anyone help?
Old Jun 5, 2009 | 10:57 AM
92civlude's Avatar
The ECU doesnt detect EGR when you first start it up. Same with the knock sensor cicuit. It sound like you have 2 problems, EGR and KS. Dont start by replacing parts on it. Test the systems first. A lot of H swaps dont have the EGR frequency valve installed. You need this if your running a p13 ECU.
Old Jun 5, 2009 | 03:47 PM
New User
yep . im running a p13 ecu maybe chipped due to vtec kicking in at 5 insteads of 5-8
how would a go about testing the system
93prelude615
Apr 9, 2008 04:27 AM
AnthonyG2003
Jul 7, 2006 07:00 AM
zojirushi
Oct 23, 2002 08:16 PM
CBR
Sep 20, 2002 08:09 PM
