H22a1 Into 94 Integra questions
im putting a usdm OBD1 h22a1 into my OBD1 94 integra, im getting ready to drop the motor in but have a question about the wiring harness, can i use the stock wiring harness on the h22a1 that was originally in the 94 prelude VTEC? and also do i need a resistor box or can everything jsut plug right in?
Re: H22a1 Into 94 Integra questions
Search https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/ that should answer all your questions. 94 to 95 integra used OBD1 harness same as the 92 to 95 civic so that write up should help you out.
thx, yea i thought that thread would be about the same but i was also trying to see if its possible that i could use a civic single cam obd1 wiring harness on an integra just in case i couldnt find an ls wiring harness
yes you can, some wires will need to be extended .
