wiring obd1 dizzy to obdo b16??
i think i have an obd1 dizzy(i think) the sticker reads TD22 if that helps, it has no plugs(cut wires) and i need to wire it to my obdo b16 in my 89si, any diagram on this or is it really obd1??
Re: wiring obd1 dizzy to obdo b16??
Must have OBD0 distributor in OBD0 application. THe sensors inside of an OBD1 distributor work comletely differently and will not work on an OBD0 car without an OBD1 ECU conversion. You can pick up one for around 140 to the door. Or even cheaper used. Good Luck
crazyef8
10
04-20-2009 09:44 PM
ludesrv
05-12-2007 08:58 PM
wfocrx
09-13-2006 06:29 PM
