Need help with h22 swap!! Clutch lines?
What do I runfor hydralic clutch lines? Stock h22 lines won't work will they?
I prolly have to get something custom? Anyone know somewhere that does it
Re: Need help with h22 swap!! Clutch lines?
I put a H22 in an EG and ran the a combination of stock D15 and H22 clutch lines, its worked a treat. IF you do need to make up custom lines then do it yourself using some brake line, and a pipe flaring tool. The old unions can be reused
HTH
HTH
UpstateCivic
04-27-2003 12:15 PM
