lsvtec header clearances
Old Apr 22, 2009 | 04:39 PM
blkwidw98's Avatar
Default lsvtec header clearances
i have a ls vtec swap in my 98 integra ls,(b18b1 block/99 b16 head). im just curious i have a good deal on some hytech replicas. but im not sure if they will clear the oil pan. the current owner has them on a ls, but when i add the b16 head will they rubb or hit the oil pan or even sit to low for clearance ground wise. also what headers will work for this swap, im goin to be running a 2000 stock gsr exhaust with eletrick cutout. also what other headers will work as far as clearance and performance wise for my swap
Old Apr 23, 2009 | 07:24 PM
blkwidw98's Avatar
Default Re: lsvtec header clearances
sumone has to have a lstvec on here, just need to kno what specific headers will work like gsr ls itr etc.....
Old Apr 23, 2009 | 07:42 PM
JDM-EJ698's Avatar
they should all work.
Old Apr 23, 2009 | 07:43 PM
blkwidw98's Avatar
but ive heard that sum headers will not clear the oil pan because im using a b16 head with b18b1 block and the clearance wont be ok and it will hit oil pan
Old Apr 23, 2009 | 08:49 PM
stevenDAtegra's Avatar
Our ls vtec motors are pretty tall but you may have the chance of clearing. Why not test fit it before you buy it or just take the chance and get it. If it doesn't fit, you can probably find a friend or someone else who will buy them. You can even use them on another b series in the future
Old Apr 23, 2009 | 09:00 PM
blkwidw98's Avatar
the reason y i dnt wanna test fit it is because ill b putting the swap in in 2 weeks and im not dropping the motor for it, and if it doesnt work then im gonn ahave to take the swap back off and put ls head back on until i find right header to fit. idk bout other ppl but im not takn chances testng things out like that wanna get straigth answer from sumone who has this swap in there car and can tell me what application headers they have
davidluko
Feb 12, 2009 11:58 AM
HondaFanatic708
Nov 4, 2005 03:20 PM
underpressure02
Jun 28, 2005 02:38 PM
dawalude
Jan 25, 2005 10:49 PM
kingrobby
Dec 20, 2004 05:07 PM
