D15 parts onto gsr
D15 parts onto gsr
I have a alt/starter/vss from a 92vx and was wondering cause its obd1 that if
i run my gsr setup as obd1 that those parts would work? Thanks
Re: D15 parts onto gsr
I know but it will be wired from a d15b harnes. So i figured at least the alt
would work if it will bolt up and sits right.
it might plug in, but not bolt in... due to the hole not linin with the brackets.. careful though, i think the amp out put is less than what a gsr needs.. so i wouldnt do it.. where you located?.. some1 usually has 1 layin around.. but make sure if you find 1, that you use the rightful brackets.. in etc. ls alt with ls brackets, gsr alt, with gsr brackets, they are different. good luck!..
yeah hes right about that not bolting in... if u use that alternator, u will need a custom bracket. totally possible.. we run d-series alts on H's..
if it dont plug in then wire a new one in.
this is the Hybrid forum.
